I am new to yamaha's (sea doo guy) . What are good compression #'s for this ski. What variance should you see between cyl's?? These seem to have good reputations for reliability, anything to be aware of or problems to check ?? Thanks in advance !!!?
'00 xl1200 LTD compression ????
On that particular year and model, you really need to update the power valves and install one of the aftermarket pin guides. There are two problems with the design, one, the older powervalves have shoulders that break and let the valve drop into the piston. Two, the OEM pin retainers do not capture the hinge pins and can let them vibrate out and let the valve fall into the piston. We sell both the new valves and pin retainers, so does R&D and Riva.
Hi again! Enough I am really worried. I am owner of a bought GP1200R 2001 in Argentina, almost do not exist services that are dedicated to make these changes in my country..... Really these problems of the PVīS are going to me to happen someday or this is an update to obtain more performance in the engine. Thank you very much by the aidArielARG
Bryan
I am looking at a '01 xlt with 110 hours and 110,115,110 compression. It seems to run ok (This is on the hose...its cold up here in the great N.W.) any thoughts ????
thanks again
Ron
[ November 13, 2002, 12:28 PM: Message edited by: imaduner ]
