Minimum amount of water inside in a GP1200-01
  • Minimum amount of water inside in a GP1200-01
    Hello friends: I would wish to know if is typical or not that exists a minimum amount of water underneath the seat (under the turbine axis) after ride a pair of hours. Could be spray of water due to the rotation of the axis? Exists possibility of water entrance by the prow when the tank is totally full? Thanks for the aid! Thanks.
    ArielARG
    If you have water in your hull, it's either from a leak in the cooling system, coming in the drain fittings, splashed in over the top, leaking in throught he driveshaft or you have a crack. There should be no water entering the hull if everything is normal and you aren't subing the ski or otherwise getting water up onto the hood.
