750 Kawa Keihin install
OK, got the choke plates and mechanism out. Ready to install the fittings. Any pointers on getting the brass fittings onto the carbs?
One is solid one has the fuel fitting. Does the solid one go in from inside the throat? Which side of the card for the fuel fitting, it can be the side with the shroud like thing over the end?
Any help would be greatly appreciated, im in the middle of installing this thing..
What about primer pump install location, any tips?
Thanks in advance, Tommy
