I Have A 96 Sea-doo With A 587 White Rebuild From Sbt Totaly Rebuilt The Carbs. Pop Off Set At 28.5, New Fuel Lines,clean Filter,fresh Gas And New Oil. New Spark Plugs Ngk-br8es Have Tryed Many Sets.ran Fine For About 20-to 30 Min On Flush Kit At 10 Min. At A Time 45 Min. To Cool Down.took To River Started Fine And Ran Fine For About 1/2 Mile And Then Died It Did Not Lock Up.but Would Not Restart For Nothin. Back At The Shop Checked Plugs And Replaced With New Set Checked Fuel Filter Ok.comption Is 135psi In Mag: Cyl. And 136psi In P.t.o. Cyl. Looking Down Into The Carbs With A Light I Can See A Mist Of Fuel As It Turns Over.trys To Run For About 3 To 5 Sec. Then Nothing. Good Hot Spark+ Fuel+ Comp= Run ???? Good Batt. Stays At 13+ Volts While Cranking Over....
Need Some Help
Re: Need Some Help
Originally posted by REDLINEGood Hot Spark+ Fuel+ Comp= Run ????
Good Hot Spark that occurs at the proper time to ignite the air/fuel/oil mixture + Fuel (fuel and oil)+ Comp (air)= Run ????John Kubiak
Las Vegas, Nevada
Sea-Doo Tech 13736
