717 Rotax misfire when throttle open almost full
I am not sure whats going on, I have a 96 GTI 717 Rotax that seems to misfire when you get the throttle 3/4 open. We are doing 45 mph on the ski and it seems to start and run fine otherwise, the misfire is only at when throttle opens past 3/4 and its very definite, you back off on the throttle and it goes away, go harder on the throttle and its misfires or sputters, hard to tell. Is there a rev limiter thats engaginging or is it a simple adjustment on the throttle cable thats allowing it to open to far causing this problem, any help you can give me would be greatly apprectated. I have wondered if the timing is off or what, runs perfect otherwise, gets up and goes with no hesitation until you reach the 3/4 throttle point, any insight would be greatly appreciated as I just bought the thing and hoping I did not get taken. Thanks in advance
