Can you identify this engine ?
This topic is closed.
  • Can you identify this engine ?
    HI,
    I have recently got a watercraft called a stinger jet which is made by suzuki.
    I need help in identifying the engine. It looks very similar to those found on tigershark watercrafts but I need to know if the crank,rods and pistons will also be the same.
    This engine is a suzuki type PJ650. It has two seperate cylinders and heads. Each head has "650" cast on it. The engine tag says the bore is 78 and stroke is 58.
    I can send photos of the engine.
    Please help me identify this engine so I can buy parts to rebuild it.
    Re: Can you identify this engine ?
    You already posted this in the appropriate area - do not cross post. Closed.
