Results 1 to 2 of 2
    Sep 2005
    79
    Question Can the STOP button be stuck???
    I know this is a far fetched question, but on a 1996 GSX, could the Stop/Start button be broken and cause it to not have any spark?
    I've seen on the board that randomly some peoples "No Spark" problem is the start/stop button.
    I am not sure if this can be possible since there is only 1 button to both stop/start the engine.
    Anyone ever experience that? Any info will be appreciated.
    Aug 2001
    Las Vegas, Nevada
    1,220
    Default Re: Can the STOP button be stuck???
    On your model, the start/stop switch provides a ground signal to the MPEM. There is only one set of wires the MPEM monitors the engine status (off or running) and provides the appropriate output (+12v to solenoid or ground to CDI output).
    So the switch is either good or bad.
    John Kubiak
    Las Vegas, Nevada
    Sea-Doo Tech 13736
  1. help wont stop cranking
    By N motion performance in forum Sea-Doo
    Last Post: 12-31-2007, 02:04 AM
  2. 96 WBII Won't Stop Running
    By cpearre in forum Yamaha
    Last Post: 08-14-2005, 09:31 AM
  3. Starter will not stop on GP1200
    By Mac-attack in forum Yamaha
    Last Post: 07-18-2005, 02:34 PM
  4. 95 gts start button same as 94?
    By hootie in forum Sea-Doo
    Last Post: 07-15-2005, 12:09 AM
  5. 97 gts starter button
    Last Post: 07-13-2005, 11:02 PM
