Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: another defect?
    May 2005
    Los Angeles(Hollywood)
    425
    Default another defect?
    I got my new SBT engine about 2 weeks ago. Everythign seemed just the way it was except for one thing upon assembly, the oil pump adapter was missing, or rather, had no way to work w/ this new crankshaft design. But was told that there has been a new updated adapter that wraps around the flywheel nut. It was said that this design is much more efficient.
    What i want to know. has anyone experied a problem w/ this adapter? After riding mine for about 2 gas tanks (96 xp) w/ this new adapter peice, the fingers on the adapter broke, leaving the NEW (less than 5 hours) oil pump to have NO USE. Because of this, it has caused a siezure to one of my cylinders, with no compression (60 psi) this is the second engine from SBT i get. Origianlly, i expected to install my oil pump the way it used to, w/ the older design adapter.
    After installing this engien and takign it out, it ran like a champ, everythign was the way it shoudl be. everythign ran correctly, and very happy. Now, after another siezed engine, i just dont know what to do anymore. should i go on w/ this again?
    Because the way this engine ran, i do have hope that my next engien will run correctly. But is there a way to get my same engien w/ the older design adapter? I really do not like the idea that this new design uses fingers to grap against the nut. I'm very stressed and frustrated. Is there any way for me to get my new engine to come to my doorstep before i send it out to SBT?
    thanks.
    21,545
    Default Re: another defect?
    You have to be kidding me.
    I have NEVER EVER heard of an adaptor failing like that, and the design has been used for over 8 YEARS on 787, 787RFI, 951 and 951DI engines. The adaptors we send out are direct from Sea-Doo too.
    No we do not ship warranty engines without the return of the failed unit.
    Call into warranty and we'll get you another block in the works.
    May 2005
    425
    i know, thats exactly what i said, i really do not know what to do. this engine ran so well. i was amazed, after all the previous chaos. i had no hope, this engine really turned it around. adn then i find out it stalls after riding at high rpms(lockign up), really coudlnt figure out why it would sieze. until i test the compression to 60 PSI. tear it apart, and this is what i found. i think i just have bad luck with this. i really dont know. when an engine runs w/o oil, will one cylinder usually fry up? also, waht should a normal running piston look like after about 2 gas tanks? any pics woudl be reall appreciated.
    is there a chance to get the old style crankshaft to use the older style designed adapter?
    why doens't sea-doo make the new style adapter like a socket rather than to use it w/ just fingers. i would assume a socket style adapter woudl be much stronger
    21,545
    May 2005
    425
    the other piston has a lot of dark spots, is that a sign of lack of lube? it doens't look anywehre near the normal running piston.
    21,545
    There is no point in guessing until we can get it back and tear it down. If you know the oil pump had a problem, you can stop right there.
    May 2005
    425
    what do i do now? do i use this same design and hope it works the next time and not break on me? or should i rely on the older design?
  8. #8
    21,545
    You don't understand. The CRANK is different, not just the adaptor - you do not have a choice of 'styles'. The numbers simply say there is no 'issue' with the later style, period. I really can't even guess why you had a problem - pictures may help. Perhaps Bill can think of something, but I simply have no experience with it's failure, ever. I can't even think of how you could install it incorrectly and have it work for more than a few seconds - maybe Bill can.
    If by chance you get the older style crank in the next engine, that's the type you'll need. It's more likely you'll have the later style though, as there are far more in the field and thus far more that we use.
  9. #9
    May 2005
    425
    i was just totally bummed out to find out all the fingers missing when i pulled the cover right off. i was in total shock. i do know it was working at one point because when i had trailor tested it, i opened up the oil pump lever all teh way to see if it was moving, and i saw small tiny bubbles moving. i do know it was working at one point. btw, all the fingers were stripped off. i'll be filing a warranty claim tomororw. thanks for the help. if anyoen else has any input. i woudl apprieciate it.
  10. #10
    Mar 2004
    WI
    352
    could it be a bad oil puimp?
    like the pump failed / locked up, and as the motor kept running, the fingers broke off of the adapter? i always recomend to my customers, to put on a new pump, or remove the oil injection all together. it jsut isn't worth it. even getting another motor, for free under warrenty, it is still alot of work, and down time on your doo. good luck. zig
    please visit my link with pics of my many parts for sale
    http://pg.photos.yahoo.com/ph/radracingpics/my_photos
    email radracingpwc@aol.com
