$2500
This ski is basically a replica of Scott Watkins' ski, with a few additional mods, optimizing it's performance in surf and freestyle riding - mods which improve throttle response and maximize acceleration "out of the hole", while maintaining or actually improving reliability and top speed.
1988 Kawasaki JS550-A7 ($2500)
Milled cylinder head with thick SST (stainless steel) head washers ($40 + $25)
Bored pump nozzle ($40)
15 degree Skat Trak SST impeller ($195)
Butch's top loading intake grate ($90)
PJS speed ride plate ($56)
PJS SST bulkhead/driveline support ($76.10)
Jetinetics lightweight charging flywheel ($444)
Butch's rev limiter eliminator kit ($10)
2.5/2.3 needle and seat (44 Mikuni carb) ($20)
Mariner engine flush kit
K&N flame arrestor kit with Acerbis splash protector ($54+)
PJS primer kit (eliminates carb choke plate and shaft) ($20)
PJS exhaust - reed pipe and manifold ($475)
PJS Type II Works rear exhaust system ($539)
PJS heavy duty 1/2" cooling system ($48)
Ports matched and polished
Crankshaft trued and welded by PJS ($48)
Rule 500GPH electric bilge pump with surface mount switch ($20 + $67)
Handlebar pole spring, bars, grips, trigger throttle
Sano Pad full tray pad kit ($72)
Castaic hood latch kit (not installed yet) ($28)
Odyssey PC625 AGM battery ($90)
(all PJS, Butch's, Acerbis, Sano Pad OOP)
- original owner
- excellent mechanical and cosmetic condition
- original paint and markings - not faded
- never wrecked, small number of minor chips and wear consistent with normal wear
- kept in enclosed garage and covered for entire life
- additional info and photos available upon request
- located in central NC
- buyer accepts responsibility for full cost of shipping/delivery/insurance
- item held until check clears
- payments accepted as bank check or USPS money order only
less than 4 hours on ski since 2000 maintenance -
2000 - engine completely torn down, inspected, new seals throughout, carb rebuilt (POP @ 8 PSI)
1992 - overhaul by PJS - new seals, cylinders honed (boring not needed)
1990 - top end rebuilt - 1st overbore
Also available with or after ski sale-
Single ski galvanized trailer
Hydronetics shop stand
Atlas beach transporter ($230)
Beach stand, PVC ($50)
Factory Pipe 550 Limited Pipe ($260)
SuperTrapp Liquidator exhaust silencer ($150)
PJS aluminum fuel filler plate and tank plug (installed on tank) ($45 + cost of tank)
Hydronetics freestyle ride plate
Mikuni needle valve springs, asstd. (used to set pop-off pressure) ($15)
Mikuni 44mm carb rebuild kit ($40)
Westcoast SST shim assortment kit (used in aligning motor, driveline, pump)($65)
PJS carb pop-off pressure tester ($53)
Westcoast driveline coupler/flywheel holding tool ($40)
Westcoast driveshaft tool ($11)
Castaic flywheel puller ($20)
(all Hydronetics, Atlas, PJS, SuperTrapp OOP)
[/img][/img][/img][/img][/img]
interested? PM or e-mail me by clicking on "prillernut" in my avatar -
- original owner
