My FX140 has all of a sudden lost power, I was riding it on the river and when i locked through a dam i sucked some stuff up my intake, Which would not allow me to go but about 5 Mph. I took the grate off and found a fishing bobber stuck on my impeller, i remove the bobber which helped but now only able to go about 40 MPH. When i got home i took the grate off again and checked everything out, the were no scratches on the impeller wall nor was the impellor damaged. I have not been able to figure out why it has lost power.
FX140 Has Lost Power Help????
Re: FX140 Has Lost Power Help????
You need to pull your pump and inspect. It is unbeleivable what will cause a subtle or major decrease of power. A single piece of fishing line, weeds, the trailing edge of an impeller, etc. Especially look at the trailing or back of impeller. A slight bend will cause major power loss. You probably removed the line and bobber from the area you could see, but the rest is stuck in the pump area you can not see
the threads are locktited need to use a small propane torch to heat bolts ,as for the ones already stripped you will have to remove epoxy from around panel nut inside hull & hold with vise grips be sure to find correct nut. good luck, you can do it!
