I have been having trouble recently with pulgs fouling on my 2001 Ultra 150. Had it in shop twice, both times, they replace the plugs and say can't find anything wrong, water test, runs fine. After 4 hrs, plug start fouling again. Always seems to be #1 plug, then #2. Appears to be gas starved and fouling from oil. I also notice the fuel filter is practically empty. Checked fuel lines, filters and check valve, all ok. Thinking the pulse fuel fitler is weak, given the order that the plugs foul (furtherest away first) and the fact that it can't seem to keep the filter full of fuel. If the pump is pumping correctly, shouldn't the filter be almost full?
Ultra 150 Plugs Fouling
Re: Ultra 150 Plugs Fouling
You may want to try the NGK Iridium spark plugs. They are expensive but lots of people say that they never get any fouling using them. Here is a link about them at NGK:
http://www.ngk.com/results_appOther....D=27661&mfid=1
Many times, in the many years I have been working with many different types of vehicles and engines I have found a common installation mistake made by many people; novice and expert alike.
THEY DO NOT PROPERLY TORQUE THE SPARK PLUGS!!!!!
The specs are 17 foot-pounds or 1/2 to 2/3 of a turn after the crush washer touches the cylinder head.
This can and will have a direct effect on spark plug life, and the plug's ability to resist fouling.
This is quoted directly from the NGK Spark Plug website:
Athough this website does not specifically state "for PWC" the same data applies.
http://www.ngksparkplugs.com/techin...1300&country=US
"Torque is one of the most critical aspects of spark plug installation. Torque directly affects the spark plugs' ability to transfer heat out of the combustion chamber. A spark plug that is under-torqued will not be fully seated on the cylinder head, hence heat transfer will be slowed. This will tend to elevate combustion chamber temperatures to unsafe levels, and pre-ignition and detonation will usually follow. Serious engine damage is not far behind.
An over-torqued spark plug can suffer from severe stress to the Metal Shell which in turn can distort the spark plug's inner gas seals or even cause a hairline fracture to the spark plug's insulator...in either case, heat transfer can again be slowed and the above mentioned conditions can occur."
Make sure to properly gap/install/torque your spark plugs.John Kubiak
Las Vegas, Nevada
Sea-Doo Tech 13736
