Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Sep 2005
    Canada
    16
    Question Jet Pump Leak tester (P/N 295 000 085)
    I'm changing my jet pump oil and I see posts on this site that say you need to test your jet pump for leaks, Do most people do this or is it optional?
    If you need to do this where do you buy this tester and is this tester a general tester or just a tester made for doing this one task?
    Jun 2002
    Nashville, TN
    81
    Default Re: Jet Pump Leak tester (P/N 295 000 085)
    Most people need to do this unless you like to run your boat with water in the pump as a lubricant. You can get a pop off tester by calling Watercraft Magic 626-914-9509
    Sep 2005
    Canada
    16
    Can this test be done while it is full of oil?
    Jun 2002
    Nashville, TN
    81
    Yes
    Jul 2004
    Carlsbad CA
    147
    It should be done with oil in it. If water gets in the pump you will ruin the bearings that can lead to destroying the pump. Bill at watercraft magic sells the desired Mikuni pump. 10 seconds at 10psi. My Ex-dealer was testing for 2 or 3 seconds. I destroyed the bearings and now do my own pump service.
    Sep 2005
    North Central Minnesota
    182
    If your pump was free of water whan you pulled the cone why would you need to pressure test it? The only way it could leak is if you installed the cap plug crooked or if you pinched the new O-Ring. The cost of the pressure tester doesn't even offset the cost of multiple sets of seals and caged needles in your pump.
    Aug 2001
    Las Vegas, Nevada
    1,220
    Quote Originally Posted by Riixxii
    Some people on this sight seem to think that its their way or no way, and that is totally not the case.
    Did you ever consider that the pressure test is used to verify that the seal on the impeller shaft is not leaking?? Or that possibly the o-ring got pinched while installing the cone? The pressure test is a final check prior to putting the fill plug in the jet pump, it only takes a few moments, and is a re-assurance that the pump is not going to leak. Most Sea-Doo owners will not notice a pump that has leaked all of the oil out, and allowed water in until there is virtually nothing left of the jet-pump assembly. This used to cost well over $800.00 (plus the impeller if needed) to fix, and now with the plastic pumps, it is about a $400.00 to remedy....A pressure tester and a few extra minutes of time are a heck of a lot less expensive than the jet-pump housing and all of the components to build up a new one.
    Of course an expert tech, who is a
    Platinum Service shop
    would NEVER send out an outboard or stern-drive lower unit without pressure testing it! Why then would he choose to do this to a Sea-Doo jet pump?
    John Kubiak
    Las Vegas, Nevada
    Sea-Doo Tech 13736
  8. #8
    Jul 2004
    Carlsbad CA
    147
    The fact that the o ring seal can be installed wrong is enough to warrant the test. I have lost my bearings due to moisture. the prop shaft also needed replacing due to rust along with spring and cap. Parts alone ~ $140.00 The pump is under $50.
  9. #9
    Nov 2003
    Glendora, CA
    6,846
    Anybody who takes the gamble of not pressure testing the cone is not following simple OEM instructions. They are cutting corners.
    I have assembled countless pump assemblies and cones, pressure tested them to find that about one in 7 seven or eight leak air.
    I use oem sealants and have plenty of experence assembling the pumps and cones. And with all that experence, some still leak.
    I consider it foolish not to check each and every one.
    Way back when, I too thought I could get away without checking them. I learned the hard way that it gets expensive and takes alot of time if the impellor housing does not hold pressure, not to mention the pissed off customer.
  10. #10
    May 2005
    Los Angeles(Hollywood)
    425
    bill, how much do u sell the pop off pressure gauges for? are they mikuni gauges? i might be picking one up soon.
  1. Preseason check list!!
    By jcar25 in forum Sea-Doo
    Last Post: 08-22-2021, 05:49 PM
  2. Changing Pump Oil
    By Bob_OH in forum Sea-Doo
    Last Post: 01-14-2005, 08:43 PM
  3. 1995 750 ZXI Jet pump
    By jsp in forum Kawasaki
    Last Post: 07-08-2004, 11:50 PM
  4. 98 GTX Ltd. Hull Leak from Pump Bolts...
    By cbeastwood in forum Sea-Doo
    Last Post: 08-25-2002, 03:17 PM
  5. What to check when buying a used ski
    Last Post: 08-01-2002, 05:47 PM
