hi guys. i just got a new sbt premium engine for my stx 1100. first thing, the mechanic who put the engine on the ski didn't give me any paper work with the warranty on the engine. do you guys send the warranties paperwork with the engines? One more question, the engine is leaking oil through the muffler. is this because it is a new engine and has oil in the pipe? i started the ski 3 or 4 times with the hose on to see if the oil stops coming out, but its still coming. any tips?
stx1100 sbt engine questions
Re: stx1100 sbt engine questions
No that is not normal, nor do I know exactly where you mean. Yes we send paperwork. Call in 877 330 0231 and we can send you another copy of everything if they lost it or whatever.SBT Tech Support is here to help with your problems.
the mechanic say to me the oil is coming out because was there THAT MAKE SENSE?? you thing i need check the engine? the engine start in the first push, maybe the mix too rich??? any way to check the mix ratio on the pump??? why the ski can be burning soo much oil??
Yeah...read the link I just gave you. And stop private messaging me.
Also - if you have not actually ridden the ski on the water yet - you need to before jumping to any conclusions. Get some time on it.SBT Tech Support is here to help with your problems.
i get the ski in the water is working really good get 65 mph in few seconds i still running easy for a least 3 thanks
thanks guys
ac
:emoticonw :emoticonw :emoticonw :emoticonw :emoticonw :emoticonw :emoticonw :emoticonw :emoticonw :emoticonw :emoticonw :emoticonw :emoticonw :emoticonw :emoticonw
When I flush my boats after a salt water ride, I make sure I'm not in the grass, or it will leave a big black oil slick and carbon.
Is it oil or just black crud mixed in the water?
A 2 stroke does burn oil. It has to go somewhere out the exhaust.<b>________________________________________
Not as good as I once was
But I'm good once, as I ever was!
Retired 7x, Region 5 stand-up Champion</b>
the spill looks like crude oil, the ski only does this when i start it after it has been sitting for a while like from weekend to weekend, but if i run the ski all day and flush it, oil does not come out. but next weekend i know im gonna have the same problem.i hope youre right and the new engine will fix itself over time. thanks for the advice.
:beer
