Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Apr 2004
    HUMBLE /ATASCOCITA TX
    762
    Default Re: clanking noise!!!!!
    The noise is NOT caused fron the impeller blades hitting the housing as the previous post suggested. The noise is created fron the driveshaft splines inside the impeller having no load and (clanking) around with every revolution of the engine as the piston rod rotates the crankshaft. The noise is not made with a constant load on the driveshaft splines when in the water.
  2. #12
    Aug 2005
    Strong Island New York!!
    34
    so i shouldnt bother takin the drive apart an checkin out the bearings? Cuz when i pulled the plugs an tried to turn it by hand i could only turn it a 1/4 way then the rest i had to use an open end wrench, an i could hear metal to metal contac an i rotated the shaft.
  3. #13
    Jun 2002
    Charlotte NC
    1,868
    On a 10 year old ski you should pull the pump and replace the bearings and seals as part of normal service to the ski every 4-5 years. If they go out you are talking hundreds to replace everything that gets damaged.
  4. #14
    Jan 2018
    Bunbury
    5
    I had a customer come in with a suspected failed jet pump on his Seadoo GTX 4tec S/C. I put the impeller housing on our stand and removed the cone and then used an electric drill to turn it over no noise other than from the drill. The bearings still had grease in them. We replaced the pump and it still had a “tinny ringing sound”. I have heard that this is because they are not submerged in water to act as a cushion. We checked the impeller clearances and it was within spec.
  5. #15
    Jun 2016
    Clearwater, Florida
    278
    usually just a tiny high spot on an impeller blade tapping the wear ring makes a ringing sound.
  1. 1997 GTX making loud noise
    By traskb1 in forum Sea-Doo
    Last Post: 06-02-2006, 12:34 PM
  2. 1991 WR500 Clicking/pinging noise?
    By drewchips in forum Yamaha
    Last Post: 12-13-2005, 12:47 PM
  3. Replies: 14
    Last Post: 10-19-2005, 01:18 AM
  4. 01 Seadoo XP Engine Noise
    By gifer in forum Sea-Doo
    Last Post: 08-14-2004, 12:08 PM
  5. 94 XP - Strange noise
    By Mike McCaslin in forum Sea-Doo
    Last Post: 08-08-2004, 06:13 PM
