Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Aug 2005
    Strong Island New York!!
    34
    Default clanking noise!!!!!
    Ok guys im new to the whole pwc thing. i just recieved a 95 slt 750. The engine had been freshly rebuilt this past spring. But i have not used it since i recieved it. My problem is that when i got to turn the motor over theres a claning sound comming from the jet drive. teh previouls owner told me that it was because of salt build up in the housing. But iv also been told that the bearings need to be preplaced an if not ill end up blowing my enigne. AN i have no idea were i can get a bearing rebuuild kit. PLEASE HELP!!!!!
    Oct 2004
    Arkansas
    173
    Default Re: clanking noise!!!!!
    My best opinion would be to purchase a Clymer manual and go to www.partsland.com for the illustrated parts breakdown. I don't believe there is a kit available. Purchase seperate parts.They are a reliable company and shipping is fast.
    The Clymer manual has pics. Be sure to buy the special tool from them if your model requires it.
    And use Ultra Blue Permatex RTV sealer to seal the pump to the ski.(avail at Wal Mart)
    You will also need new seals between the pump and the ski and new rubber bumpers for the drive shaft and also 2 new seals (P/N 3610040) for the center bearing support($12.00). or purchase the entire unit($95.00).
    Hope this helps.
    Cheers !!
    Aug 2005
    34
    Thanks for the info!!! I already have the polaris service manual i just wasnt sure wich parts were needed. but the parts you sugested there still available at a polaris dealer rite? If not do you know of any links you could send me i would greatly appreciate it:emoticont
    Nov 2004
    CT
    154
    It might be normal these thing's sound like a box of rocks out of the water with no load. But you should check the bearings in the pump housing. Remove Item # 26 to remove the pump from the hull.Then check for bearing drag or tightness.
    http://www.partsland.com/index.cgi?N...750-PROPULSION
    Aug 2005
    34
    yea thats what im gonna do, cuz this thing sound like its all loose inside when i turn it over. I rather take it apart no an found out i need bearings, then risk it an blow a motor with a half hour of run time on it
    Apr 2004
    HUMBLE /ATASCOCITA TX
    762
    Is the clanking noise while running on a trailer or in the water?
    Aug 2005
    34
    on the trailer. You gotta hear it, its loud an it sounds liek the impeller is jumpin around inside. It literally sounds like its gonna fall apart.
  8. #8
    Jul 2005
    Pensacola FL
    50
    every polaris i have seen makes that noise when its on the trailer. the impeller is bouncing around inside the housing and that *ping* you hear is the blades hitting the housing cuz there no water to act as a cushion.
  9. #9
    Jan 2002
    Jefferson City, MO
    680
    They are noisy, but its worth it to take a closer look, I've seen them come off the shaft before.
    I do have a totally complete pump unit off a running 95 SLT for sale if it matters. I think I posted it in the classifieds here recently.
  10. #10
    Aug 2005
    34
    i think im gonna pull the jet pump off any way an check the bearings just to be safe. I really dont wanna risk blowing an engine with a half hour on it. But yes my drive is making that ping noise when i start it on the trailer. I tried spraying WD40 into the pump an starting it an its still clanking. Maybe ill try to inject the pump with water.
  1. 1997 GTX making loud noise
    By traskb1 in forum Sea-Doo
    Last Post: 06-02-2006, 12:34 PM
  2. 1991 WR500 Clicking/pinging noise?
    By drewchips in forum Yamaha
    Last Post: 12-13-2005, 12:47 PM
  3. Replies: 14
    Last Post: 10-19-2005, 01:18 AM
  4. 01 Seadoo XP Engine Noise
    By gifer in forum Sea-Doo
    Last Post: 08-14-2004, 12:08 PM
  5. 94 XP - Strange noise
    By Mike McCaslin in forum Sea-Doo
    Last Post: 08-08-2004, 06:13 PM
