How will the engines work with the original Yamaha Exciter (jetboat) mufflers (1100), they look quite the same but just a bit smaller exhaust connection. but if I use a rubberconverter from the Gp1300R exhaustsize to the 1100 mufflers.
Install Gp1300R engines in a exciter and use 1100 mufflers..
Re: Install Gp1300R engines in a exciter and use 1100 mufflers..
Look I don't mean to be rude, but you have no clue how these engines work. You can NOT interchange parts like that. The muffler system is an integral part of the engine system and everything needs to be matched. If you want more power in your 1100 boat, sell it and buy a later model, or custom fiberglass motor mounts, swap the jet drive systems and drop in a COMPLETE engine system of your choice.
And no, there are no 'smaller' aftermarket pipes.SBT Tech Support is here to help with your problems.
I donīt know how this engine works..? Okey!?
2-stroke machines...
Yes I can sell everything and be like the rest..
Or I can try to make the fastest exciter..?
And that the SBTīs tech support have this opinion ..?I thought you guys liked this kind of project.. But is it just aftermarket BUY-things/performance that works for you guys??hmmm
Of course I now that everything is matched to each other.. but for that reason nothing says that you can make it better or just the same but so it fits in my enginebay..I thinking of the exhaust...
Sir, if it were that easy, Factory Pipe wouldn't be spending hundreds of thousands on pipe R&D alone. But hey - good luck! :emoticonw :beerSBT Tech Support is here to help with your problems.
To make it easier, I'll buy one of your complete 1300R engines. I am sure I could find a buyer for your other one.
Rebuild the 1100s or go to a pair of 1200 npv and get 2 sets of triple pipe setups. There you have it, one kick *** Jetboat.J-me
05 Bayliner 175
98 GP 1200 Yamaha factory support hull, Lamey engine, Skat pump
Maybe take a look at this, re: 2-stroke pipe design
http://www.motorcycle.com/mo/mcnuts/em-pipes.html96 Raider 1100 - ProTec ride plate & Extended nozzle, R&D Intake grate
TS-built 97 GP1200 'sky high' edition
How do the experts think about having the exhaust like this?
Just to make a adapterplate.
And after this part of the exhaust I will make a custommade "Riva Stinger 3" pipe the way back to the Gp1300R muffler...
Itīs tight, but I can be made!
Jut take dryer ducting, shape it where you want it, then mold the outside with JB-weld to hold it to form. Works great. Don't forget the duct take at all gasket surfaces.SBT Tech Support is here to help with your problems.
