Where is the grease fitting for the drive shaft on the rear of the ski (behind impeller)? I see a cone-shaped cap that has 3 bolts on it's circumference and one bolt in the center. I was going to take the center bolt out and place a grease fitting here but when I did, clean grease ran out like it was under pressure. Where do I need to supply grease to these bearings / seals?
My old Kawasaki's have a fitting in the center that you can see when looking into the pump nozzle from the rear.
I am aware of the drive shaft holder fitting that supplies grease to the bearings where the shaft goes thru the hull (behind engine coupler).
