Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    May 2005
    Cali
    18
    Default Winterizing bare minimum
    :D Hi, just wondering what the bare minimum I need to do to winterize my ski's. I have 2ea. 04 seadoo gtx S/C . Just took them to the river about 5 times. I think i have 40 hours on them. I store them down there and really don't want to have to pull them back here. I would like to do it down there and leave them there. What do you think. I thought most people just pull the batteries until I read all the other posts about the subject. Kinda amazed me!!!
    Sep 2003
    52
    Default Re: Winterizing bear minimum
    fuel stabilizer in the tank, run for a few minutes top off tank.
    remove fuel rail, spray SD lube in the cylinders, put in drown mode and crank for 10 seconds.
    take battery out, fill with water if needed and put on battery maintainer or charge 1 X/month
    next year you'll have a bit more. Buy a shop manual in the off season.
    May 2005
    Cali
    18
    Thanks for the info.
    21,545
    Is that the grizzly or black version?
    May 2005
    Cali
    18
    Black I believe! :D
    Nov 2005
    Texas
    98
    :emoticonn should chage the pump cone oil......if you have a leak and it sits all winter, you might get rust on the internals......if you live where it gets real cold, antifreeze in the water lines too......
    Sep 2003
    52
    Although 4 tecs don't use pump oil (unless you modded it) it is a good idea to see if water made it into the pump bearings. Good catch.
  8. #8
    Nov 2005
    Texas
    98
    humm I didnt know that , learn something every day.......do they have a grease fitting on the shaft??
  9. #9
    Nov 2003
    Glendora, CA
    6,846
    No, you pack the pump by hand with special grease.
  10. #10
    Sep 2003
    52
    no zerk fitting on the driveline either.
  1. Winterizing a Yamaha Deluxe 110 Waverunner
    By amateurwaverunner in forum Yamaha
    Last Post: 10-19-2007, 11:49 AM
  2. Replies: 26
    Last Post: 10-14-2007, 11:01 PM
  3. winterizing? where to putt anti freeze?
    By skeeee in forum Yamaha
    Last Post: 11-17-2005, 12:41 AM
  4. Winterizing 04' FX HO
    By dundeels in forum Yamaha
    Last Post: 12-01-2004, 12:08 PM
  5. Yamaha Waverunner Winterizing
    By Time2kil in forum Yamaha
    Last Post: 08-26-2004, 07:12 PM
