Results 1 to 3 of 3
Thread: 760 xl problem
  1. #1
    Joined
    Mar 2003
    From
    West Coast Fla.
    Posts
    4
    Angry
    Hey Ya'll! Took the waverunner out on Monday for the holiday...it was working fine at home before we left.
    Loaded it in the water and got it going and it only went up to a speed of 8mph max at WOT. I could hear the engine trying to kick in, but there was no rise in the speed. After a short, short ride, it stalled. I could get it started again, but it would not stay started. It would just stall. Loaded up and went home. What a waste! We were disappointed. [img]graemlins/crying.gif[/img]
    Now, I don't know what to look for or at first! Battery is fine and that is about the extent of my knowledge. Sorry. :(
    What could it be? Spark plugs, fuel filter, intake, carbs???? Action Sports here in Bradenton said it might be something stuck in the intake. What do you think? I don't want to spend $$ unless I HAVE to.
    Thanks in advance for your help!
  2. #2
    Joined
    Mar 2003
    From
    SBT
    Posts
    21,545
    Post
    What I'm suspecting is that you either have massive pump damage, or something cloggin your intake, yes. Also, these engines don't just stall - you may have been seizing it, probably due to an overheat, if your pump was obstructed or cavitating that badly and you were reving it up. NEVER revup the engine or try to ride it if it's got pump damage - that's also the cooling water supply to the engine!
    Right now you need to inspect your pump and do a compression test on the engine to see if you have done any damage so far.
  3. #3
    Joined
    Mar 2003
    From
    West Coast Fla.
    Posts
    4
    Post
    I had cleaned out the cooling lines last weekend before we took it out-seems to be par for the course in salt water. I will inspect the cooling lines again and the intake, but I do not have the ability to do a compression test here at home. I guess that means a trip to the shop. yay.
    After it stalled during the first ride, I started it back up and it promptly petered out when it was without throttle. I did not start it again. We just packed up. Sux.
    Thanks for your advice! I hope it doesn't cost too much, but whatever. We do want ride it when my brother gets back in a couple of weeks from Baghdad.
    thanks!
    [ May 31, 2003, 05:28 PM: Message edited by: yama fan ]
Thread Information
Users Browsing this Thread
Similar Threads
  1. 96 Yamaha Waverunner 760 Starting Problem
    By awadecki in forum Yamaha
    Last Post: 07-09-2007, 09:38 AM
  2. yamaha gp 760 speedo problem
    By jonarch in forum Yamaha
    Last Post: 09-02-2005, 09:04 PM
  3. 99 Yamaha Xl 760 Electrical Problem.
    By dewberryone in forum Yamaha
    Last Post: 06-16-2005, 03:18 PM
  4. 760 Pump problem?
    By dhud64 in forum Yamaha
    Last Post: 06-27-2004, 06:16 PM
  5. 99 760 XL porpoising problem??
    By gelbaum in forum Yamaha
    Last Post: 07-06-2003, 09:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
