I have a 1998v gtxl, while installing a newly rebuilt motor I made the mistake of hooking the rave valve line to the water box regulator outlet. I ran the ski for five minutes before realizing what had happened. I switched the lines back then proceeded to pump the water out by removing the spark plugs and cranking the engine over etc. I also removed the rave valves and removed all the water from the bellows.
I put brand new spark plugs in and ran the ski again, the ski ran fine but when I shut the ski off and try to restart it, it fouls the plugs instantly and I notice that there is water on the spark plugs so I put new spark plugs in the ski, it fires right up and runs fine until I cut it off again then it does the same thing. I have used 11 sets of plugs. Can you guys please help me, I don't know what else to do?????? Thanks Ian.
