Last post - Jet ski won't run in saltwater
  • Last post - Jet ski won't run in saltwater
    1989 Kawaski 650 jet ski
    Got alot of the same reponses....Thank you!!! Mostly the response was to use dielecletric grease on the connection of the plugs and the threads. Took it out today(sorry have to rub some noses in the beautiful weather sunny and 77). Got it started and it would idle, but as soon as you put any body weight on it it acted real sluggish, then would die. It Did idle around back to me, but really could'nt keep it running. Any other ideas??? Just FYI, Did take in fresh water three weeks ago and road the heck out of her.....HELP, I wannna ride!!!!
    Stacy
    Re: Last post - Jet ski won't run in saltwater
    Do a compression check and report back. Ill bet its low.
      Ran a compression test. Not sure what they should be at, but both are reading 100. Please advise
      Stacy
        Buy a can of silicone spray. Spray the entire engine and electrical box and battery top where the cables connect. Spray the connector from the start stop button and all wiring.
        My total loss boat did this very thing the first time i sat it into salt water. That is when someone handed me a can of silicone spray.
        <b>________________________________________
        Not as good as I once was
        But I'm good once, as I ever was!
        Retired 7x, Region 5 stand-up Champion</b>
          If your plug wires arent in very good shape, the salt water makes it much easier for the spark to short to ground. It might be time for plug wires or a coil. start up the eninge in the dark and see if the plug wires are shorting to ground somewhere.
            Will sure try, Thanks
            Stacy
              my old X2 did the same thing but it wasnt from water. it turned out to be a torn headpipe to expantion chamber coupler.
                Mike, are you also known as "jumpmaster03"???
                John Kubiak
                Las Vegas, Nevada
                Sea-Doo Tech 13736
                  yep, thats me. i couldnt change my screen name without creating a new login. but yea, thats me.
                    Isthis something the average mechanic canrepair or does it need to go into the shop?
                    Stacy
                      I was asking because I sold you some parts on e-bay! does "snappyqb" ring any bells????
                      John Kubiak
                      Las Vegas, Nevada
                      Sea-Doo Tech 13736
                        sent you a pm
