I want to check my charging system on my 2001, 1100 STX DI.
I found the plugs where the test prongs insert. The book calls for the special tools Needle Adapter Set 57001-1457. I have a pair of tip extensions. The extensions are made of stainless steel with a polished point. The outside Dia of the needle is .045" The needles are 4" long, and have a sharp end.
Could I cause any problems by inserting these needles into the plug?
If I do use the tester, what should I use for a ground?
