Results 1 to 2 of 2
    Aug 2005
    Metamora, IL
    16
    Default 750 SX Hard Starting Starting
    I have a 93 sx which has a history of hard/no starting. I literally spent more time trying to start this thing than riding it. it seems as though I start it in the garage and it and starts with no problem 85% of the time. Then I take it to the lake and I can't get it started so I take it home and it sits and then the next day it starts up with no problem.
    When it does start it runs great, ver strong and once started and warm it seems to start up over and over with no problems, but If I let it sit even to eat lunch or something then I have a hard time getting it to start again.
    I have rebuilt the motor with all new gaskets and am sure the crankcase is sealed with 1211. I have tested compression and both cylinders are both at 187psi.
    When it wont start, I can verify spark by pulling the plugs and cranking and I know I have fuel because I have a primer installed and I can see the gas being pumped in to the carb manifold through the lines. I have also inspected the reeds when I rebuilt the motor and they are like new.
    any suggestions?
    Aug 2001
    Las Vegas, Nevada
    1,220
    Default Re: 750 SX Hard Starting Starting
    Thank you - SBT Mgt.
    John Kubiak
    Las Vegas, Nevada
    Sea-Doo Tech 13736
  1. 96 kawa 750 not starting
    By Texas Rider in forum Kawasaki
    Last Post: 08-24-2005, 10:35 AM
  2. 89 SP Hard at starting...?
    By broncojared in forum Sea-Doo
    Last Post: 06-10-2005, 01:12 PM
  3. hard start 750 STS
    By cubman in forum Kawasaki
    Last Post: 02-28-2005, 11:12 AM
  4. Xi 750 hard starting
    By johnn in forum Kawasaki
    Last Post: 12-05-2003, 11:30 AM
  5. Hard Starting on Kawi 1998 1100ZXi
    By TJ in forum Kawasaki
    Last Post: 01-15-2002, 02:49 PM
