Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Jul 2005
    Alabama / Birmingham
    53
    Default Sea doo XP Motor Hard to start New SBT motor
    I just bought an SBT motor and put it in a 1997 XP. Here is the probelm when trying to start it. it roll over fast the all of a sudden it locks like its flooded then starts rolling fast again it will fire every once in a while. It has fuel/ spark and compression please help..... I got it to start one time but I had to hold the the throttle at about 1/2 to keep it running when it was running it seem to be running fine.
    21,545
    Default Re: Sea doo XP Motor Hard to start New SBT motor
    That sounds like a possible bad starter, where the bendix is not retracting. I would at least remove the starter and inspect it's one-way clutch, to make sure the teeth are not damaged and it operates smoothly. If that looks good I would inspect the flywheel to make sure the ring gear has not moved on the hub, and all the teeth are good.
    Jul 2005
    53
    I did that what else do you have to try?
    Jul 2005
    53
    is it possible I have the rotarty valve off timming? I dred having to yank the motor to re degree it.....
    21,545
    No, the rotary would have nothing to do with it. How long does it turn over before locking? Is it the same amount everytime? Have you tried taking the plugs out and turnign the PTO by hand?
    Jul 2005
    53
    No it's not the same amout of time that it locks
    yes it turns smoothly
    21,545
    Then I'd say you missed something or didn't know what you were looking at was damaged. If it turns ok by hand, it's nothing internal.
  8. #8
    Jul 2005
    53
    like what?
  9. #9
    21,545
    Like everything I already mentioned. I would suggest taking it to a shop.
  10. #10
    Jul 2005
    53
    Thanks for nothing....:emoticonr
  1. Replies: 37
    Last Post: 06-14-2008, 12:58 AM
  2. 97 XP New SBT Motor will not start! Help
    By WPBSeadooXP in forum Sea-Doo
    Last Post: 10-09-2005, 09:24 PM
  3. 96 Sea Doo Xp won't start
    By harsha in forum Sea-Doo
    Last Post: 09-12-2005, 12:56 PM
