I noticed on your website you have the high flow fuel pump for the slt750. Does the pump mount were the stock pump origannally was? Does it come with instructions as how to install? An do my carbs need to be retuned after installing the pump? Thanks!
hi flow fuel pump
Re: hi flow fuel pump
Yes it comes with a chart and instructions. It supply fuel to #1, leaving the stock pump to supply 3 & 2. http://www.sbtontheweb.com/Merchant2...tegory_Code=a1SBT Tech Support is here to help with your problems.
