i order the oil block off kit for my xl700 from sbt. Is there anything special i need to do. I see on sea doo you still need to make sure there is oil for the bearing. Any info would be great.
xl700 going pre mix
Re: xl700 going pre mix
Nope, real slimpe on that ski. Remove the pump, bolt up the plate, plug the two inlet fittings. You can leave oil in the tank and plug the line, or you can drain the tank and jump the two sending wires together to show a 'full tank'.SBT Tech Support is here to help with your problems.
