Reed Valve
  • Reed Valve
    I just purchased a SBT 951 and in taking the accessories off the old motor I found one of the reed valves damaged. Should I replace the reed valve box for both cylinders as a pair or is it OK to just replace the damaged one?
    Re: Reed Valve
    You only need to replace the damaged one.
