Results 1 to 2 of 2
    May 2005
    Virginia
    3
    Default 2002 GTX 4TEC still leaking coolant!! HELP!!
    After de-winterizing, took my first ride yesterday. I'm still losing coolant, even after re-inspecting all hoses, clamps, etc and pressure checking system. Did notice a very small amount of coolant coming out of weep hole at base of water pump. Had to use small inspection mirror even to notice that. Anyone experienced a rotary valve failure? Or is this normal? Should I be looking for any other problem areas?
    21,545
    Default Re: 2002 GTX 4TEC still leaking coolant!! HELP!!
    Thank you - SBT Mgt.
  1. GTX 4TEC coolant in engine oil problem
    By mazzerman in forum Sea-Doo
    Last Post: 04-28-2007, 07:30 AM
  2. 2002 GTX 4TEC Venting Battery
    By JoelF in forum Sea-Doo
    Last Post: 04-18-2007, 11:49 PM
  3. 2002 GTX 4TEC Crankshaft
    Last Post: 06-01-2006, 12:13 PM
  4. 2002 GTX 4TEC Pump Oil????
    Last Post: 10-30-2005, 09:08 PM
  5. 2002 GTX 4tec Coolant leak!!
    By pashton394 in forum Sea-Doo
    Last Post: 05-25-2005, 09:35 PM
