New fuel pump and motor will not prime
This topic is closed.
  • New fuel pump and motor will not prime
    Any of you ran into the problem of the new fuel pump not priming.
    I have a 96 slt 750 and with a rebuilt engine and aftermarket fuel pump with two outlets. I cannot get it to pull fuel to the pump. Im not sure if it is the pulse line off the crankcase that is the issue? Any thoughts on the problem?
    Re: New fuel pump and motor will not prime
    Thank you - SBT Mgt.
