Different size cylinder bore - Oversize pistons
  • Different size cylinder bore - Oversize pistons
    Is there any reason I can't bore one cylinder over .25mm and the other over 1.0mm on a 1996 SL700? I realize the ideal would be to keep the cylinders the same size but if one doesn't need it, can I just do one and not the other? Would it warp the crank over time or damage the bearings?
    Re: Different size cylinder bore - Oversize pistons
    Polaris cranks are the most sturdy to begin with. Throwing it out of balance is just asking for trouble sooner or later.
