Does the zxi 750 jet pump fit the zxi 900
  • Does the zxi 750 jet pump fit the zxi 900
    Hi.
    Is the 750 jet pump the same as the 900 jet pump. Are they interchangeable from the coupler, the shaft, the bearing housing, pump case, outlet nozzle, and the steering nozzle the same? Also, are the impeller and the impeller shaft the same?
    Thank in advance
    If first you don't succeed, suck suck till you do suckseed
    98 kaw 750 XI Sport
    2 - 95 Kaw 900ZXI
    Re: Does the zxi 750 jet pump fit the zxi 900
    I do not believe so. You can lookup and compare Kawasaki parts on www.buykawasaki.com - they have the online microfiche.
      Ok, I'll check that out. Thanks
      98 kaw 750 XI Sport
      2 - 95 Kaw 900ZXI
