Results 1 to 4 of 4
Thread: Carb settings
    Jul 2005
    Missouri
    15
    Default Carb settings
    I have a new 787 SBT engine. In your tech articles you say that a 97 SPX should have the high carb setting at 1/4 on PTO carb and 0 on MAG carb. My question is....I also have a 96 XP with a 787 engine and your tech article says the high carb setting should be 0 on both PTO and MAG. So if they are the same engine why the difference?
    96 XP 787 stock
    97 SPX 787 stock (new SBT engine)
    86 IMP 230 SC cuddy cabin
    21,545
    Default Re: Carb settings
    All settings are +/1 1/4 turn, and some book specs change year to year. Start either way, and make changes based on your needs.
    Jul 2005
    Missouri
    15
    So I should start with the LOW and HIGH screws on both the PTO and MAG carb at 1 1/4 out and then based on reading the spark plugs and performance, adjust from that point?
    96 XP 787 stock
    21,545
    No, highs are 0 to 1/4 turn out.
  1. 97 XP Carb settings
    By gnxv6 in forum Sea-Doo
    Last Post: 06-14-2019, 08:06 AM
  2. Carb Settings on a new SBT 1200N-PV Motor
    By dtd696 in forum Yamaha
    Last Post: 08-11-2007, 07:11 PM
  3. fuel pump exchange/ carb settings
    By 02_GSXR_600 in forum Polaris
    Last Post: 08-08-2005, 12:14 PM
  4. 580 White carb settings
    By VaSuperjet in forum Sea-Doo
    Last Post: 07-24-2005, 09:27 PM
  5. 97 challenger (787) carb settings
    By Hoogie in forum Sea-Doo
    Last Post: 08-04-2004, 12:44 AM
