thanks, i know that. if you read the section under wear ring replacement it says to look under something else to get step by step directions and i don't know where the heck it is. I see what your talking about
The Engine Install Removal Guides, in that section. Choose your engine size...
oh, ok, well i didn't think wear ring replacement would be under that. Does it explain step by step how to replace the WEAR RING. I don't recall seeing that in there. I'll check again.
If you mean do we have pictures, no we don't. Just follow the text, it's a very simple procedure.
