Results 1 to 5 of 5
    Jul 2005
    Laguna Vista, TX
    14
    Default 951 engine light
    SBT 951 engine starts idling around 700 rpm and engine light comes on. Idle starts at 1300 and then falls to 700. Also notice a light spray of black oil on flywheel cover. Maybe unrelated, but, fuel level gauge is not working as well.
    Ed
    21,545
    Default Re: 951 engine light
    The fuel floats on Sea-Doos never last. Your dealer can order you a new float or sending unit.
    Set idle to 3000 out of the water.
    Jul 2005
    Laguna Vista, TX
    14
    The 700 rpm reading is in the water. I have it set at 3000 rpm out of water. She idles fine and then seems to fall off to 700 rpm and then engine light comes on. Give her a little gas and light goes off and idle usually returns to normal (1300rpm) any idea what this light spotting of black oil would be on the top of the flywheel cover?
    Ed
    21,545
    What year and model is this?
    As for the oil you'll just have to look around and see where it's coming from - usually it's a leaking line or fitting.
    Jul 2005
    Laguna Vista, TX
    14
    This is a 2000 SD GTX
    I have looked around but cannot find a source for the oil would a digital be helpful.
    Ed
  1. Replies: 4
    Last Post: 07-16-2007, 12:24 PM
  2. 951 seadoo engine in a 2000 GTI
    By Jake22 in forum Sea-Doo
    Last Post: 06-19-2007, 10:29 AM
  3. SBT 951 Engine issues / question
    By superd66 in forum Sea-Doo
    Last Post: 07-16-2006, 02:41 AM
  4. check engine light, 2002 fx140
    By dare44_44 in forum Yamaha
    Last Post: 07-01-2006, 09:14 PM
  5. Replies: 12
    Last Post: 06-26-2006, 03:23 PM
