Does everything get lubricated by the fuel mix or is there crankcase oil?
I just bought this ski and it has been garaged since '99. I squirted some oil in the cylinders and cranked it a few times without the spark plugs. then I compression tested it. Im getting a consistant 110-115 in both cylinders. Could this work on 87 octane. Should I rebuild the top end to get more compression? I cant try to start it until I replace all the fuel lines. All the hoses broke off with a slight touch.
Any way I dont fully understand the 2stroke concept I guess. I have learned alot frome these forums Thanks for the info.
