First off the engine is a SBT....done this about a year ago....!!
Wouldn't of type all of this just to get re-directed....so hopefully now my questions will get answered.....thanks
Here is the ??? once again:
For some reason it finally started giving me problems at full throttle.....so bought 3 carb kits and rebuilt them....thought that would fix the problem....not saying it didn't help but it didn't fix the new problem.....of course the battery is dead and this may be the problem but took it out yesterday....jumped it off with my father-in-laws boat and started up fine....idle's fine....and takes off very well......but about 5-10 secs into full throttle it starts to cut of....like its not getting enough fuel....let loose of the throttle and it catches up to it self and then you can hit again and it takes off like crazy and then dies out at full throttle....so trying to figure out if this battery may be messing with me.....?? I know when I was loading it.....I guess the battery was finally gettin down all the way and the display was flashing on and off....and when it did that the motor would run like crap.....??? So is it the battery....?? Or stator......or fuel pump.....???
Also does each carb have its own fuel pump or is there just one for all three.....hope someone can help me out or at least tell me where I need to start looking at now....!!!
Tried to charge the battery but it didn't take a care so its really weak....if this helps anyone....
