I did the compression test the first two pistons read a little over 110 psi the last one where the noise was coming from read 60 psi so that means what?
1100 triple Wave Venture
The rings were fine but the crank shaft where the piston shaft connect inbetween there the is a bearing or a spacer kinda thing it was missing causeing the nosie i heard but the rings got pushed into the cylinder which caused the low compression now what is the best way to take teh crank shaft apart and should i replace all the bearings or spacers what ever that is between the piston shaft and the crank shaft?Greg
You can't take the crank apart unless you happen to be a crank shop. You need a new crank if you are going to do it yourself. We have the crank for $375, the whole engine for $899.SBT Tech Support is here to help with your problems.
Look, no offence, but if you have to ask, you cannot build a crank.
In phase meaning the webs are 120 deg. apart from one another, true meaning runout is around 0.002" on the ends.
It takes veru special equipment and talented people to make a crank correctly.SBT Tech Support is here to help with your problems.
no ofense taken I am still learning all the things about this type of engine I know a lot about it from recent experience but not all . Whould a manufacturer sell me the seperate parts for the crak or would they make me buy the whole thing? Also one last thing how do I take the pistone heads off the rods?Greg
You have to buy the whole crank.
http://216.37.204.203/yamaha_OEM/Yam...pe=13&A=58&B=4
You need a crank and a top end rebuild. Buying a rebuilt engine is the cheapest way to fix it.
[ August 01, 2003, 01:16 PM: Message edited by: 99gp1200 ]
I have a professional mechanic in the family that is gonna rebuild my crank shaft. Do you know where I could pick up that part between the rod and the shaft. Didn't you say you had a crank shaft for me for like 375. will it fit in my wave runner thoughit is a 1997 wave Venture 1100 tripleGreg
