1100 triple Wave Venture
  • #31
    Yes, all the Yamaha 1100 cranks are the same, we have them on exchange for $375, click Products on the left.
    Individual crank components are not sold separately.
    • #32
      Is your crank shaft preassembled press and balenced? how much is shipping? and do the rods come witht the crank?
      Greg
      • #33
        Yes they are complete, trued and welded ready to drop-in.
        Click for shipping tables
        • #34
          Originally posted by 1100 Triple 39:
          What kinda warrinty do I get with your part and what if i drop it in and it doesn't fit or work can i return it?
          I have to say what others are thinking...
          Explore the website. Almost all the answers to your previous posts are there in an organized manner.
          93 701 Blaster<br />96 760 Raider<br />68 289 Bronco
          • #35
            Hey tech support,
            Did you delete the post i said to scratch.
            I'm am just trying to work some bugs out of my computer and would like to know if you did it, or i am still having problems.
            Sorry to stray from the topic.
            • #36
              Greg
              • #37
                When you find the valves, then you are ready to take a crank apart. Did you know that the crank gets index! If you need to ask what that is just get a long block. It will be a costly experience if you build it wrong. Your cases are good so you are way ahead of others TRUST ME [img]/graemlins/winkanim.gif[/img]
                • #38
                  Greg
                  • #39
                    Yamaha part #-- LIT-18616-0144
                    Read it, memorize it, know it in your sleep before you monkey with that engine, GOOF-UP is expensive and labor involved....
                    ***1100 Venture***<br />OE head mod-- by Riva Yamaha<br />Wiseco (+ .5mm)<br />True-welded crank<br />Riva F/A+ Jet kit<br />Boyeson Power reeds<br />Riva 1100 CDI<br />NGK plugs- BR8HS<br />R&D Aqua-Vein<br />Solas 14-21 Super Camber//Impros<br />Riva rideplate<br />Amsoil "AIO" @ 50:1 pre-mix, currently KLOTZ Ski-Craft<br />MOBIL-1 grease in the pump<br />Sears Diehard<br /><br /> Dream-meter shows 65---- GPS says 54.2 mph best, 9/14/02 @ 850 ft elevation
                    • #40
                      Please click the Program button on the left.
                      • #41
                        tell me if this is a good idea before I put in the new crank shaft should I put some oil into the crank to keep it lubed until the oil pump reprimes it self
                        Greg
                        • #42
                          A cap full of oil down each spark plug hole after assembly and some turning over by hand is good.
                          • #43
                            After I put this product in assuming that there is no other damage to the engine what is the percentage of it working and what kinda life am i looking at for this engine? How long do they usually last? Is there any thing I shoudl watch out for when putting it back together?What are your hours so I caan call and order the crank?
                            Greg
                            • #44
                              You keep double posting and I see you are on a dial-up account - please wait for the page to load, don't hit reply twice.
                              The Yamaha 1100 is a firly reliable engine, 500+ hours is common. There are a ton of things to know about building the engine - please buy the Service Manual, that's what it's for.
                              • #45
                                Dude, send me your motor, I'll take care of it for you.. Buy the factory manual, and read it first. Stay away from the Clymer book, it's full of errors. I'm a certified Toyota Master tech, Nissan tech , and ASE certified Master.
                                [ August 04, 2003, 10:56 AM: Message edited by: CaptToyota ]
