? Carb kit
  • ? Carb kit
    I have a 96 Sea doo Challenger, with a 787 rotax. I ordered a kit from SBT, but I believe I ordered the wrong one. I ordered the Mikuni BN carb kit, but the gaskets are round, and My carb is square. I ordered this one because the sea doo shop book says I have a Mikuni BN 401 carb. Do you have the correct kit? If I exchange the one I just got today is there going to be a 10% restocking fee? What else should I order when I rebuild the carbs?
    Thanks in advance for your help,
    James
    Re: ? Carb kit
    Yes, you need the SBN kit. The model designation of the carb does not necessarily correlate to the rebuild kit name you need for a carb.
    Yes there would be a 10% restock fee, yes we have the SBN kits, they are $35 ea.
    When rebuilding carbs it's always a good idea to also check your pop-off pressure with a po-off pressure gauge. If you do not have one I highly recommend replacing your needle & seats along with the rebuild. If you don't do either and they are sticking/leaking, you'll just be back where you started from and need them anyway. They are about $20 ea. from a dealer, and a guage is about $50 from a dealer.
    Please read the carb rebuild guide in the tech section for more info - there are also videos in the video section.
      Re: ? Carb kit
      Do you carry the needle and seat? How much will they be? Should I also order the intake gasket set, or does the carb kit come with the carb to intake gasket?
        Re: ? Carb kit
        Yes you will need gaskets if you don't already have them. No, needle & seats are dealer only, sorry.
