787 Counter Balance Oil
  • 787 Counter Balance Oil
    Installing one of your motors in a 98 1800 challenger the book says to add oil to balance shaft at plug. Your motor has no screw in plug. please advise thanks
    Re: 787 Counter Balance Oil
    It was already filled during assembly, you are all set.
      For the curious, how do you add the oil, where if no plug and how much?
      thanks
        30ml, added before you seal the cases. Only the early cases had the plugs, that were actually not needed.
