Ok I have worked on some Seadoos for about a year done a couple of motor jobs. I was wondering what the Engine Alignment tool does? Right i Know that aligns the engine, but with the jet pump? and why do you need to use it? If you remove the engine mounts from the hull or when you short block with the mounts left in? I am sure all motors are diffrent but that diffrent that everyone needs aligned?
Thanks for you Help
Ivon
Thanks for you Help
Ivon
