Kawasaki TS 650
This topic is closed.
  • Kawasaki TS 650
    Help!!!!!!!! My 1991 kawasaki Ts 650 overheats within minutes of starting. Right after starting water spray's 2/3 inches from the bypass outlet then starts steaming and sputtering water. At that time the engine and exhaust are far to hot to touch. Also the motor will not start untill cool. I have verified there is no blockage or leaks in the coolant lines and compressed air flows freely through the entire system. Has anyone experienced this problem-if so please help.
    Re: Kawasaki TS 650
    Thank you - SBT Mgt.
