I am some what confused as to what is the proper procedure for timing the rotary valve. When I use your procedure of setting to 130 degrees from reference point (port just opening) and Seadoos procedure where they say to set it between two points at 130 degrees and 65 degrees (port just closing) I end up with approximately a 5 degree difference.
Which is the most correct procedure?
Also the 717 ports have a stepped inlet which leads to some confusion as to where the opening reference point should be. I have used the first step which is where air would just start to enter the port.
Your advice would be greatly appreciated.
Thanks,
Dave Fasken
Thanks,
Dave Fasken
