This ski had a 40-206 motor installed in 2001. I just purchased.
The oil injection system is still installed. I read in the STB manual about blocking off this system. Can I buy the block off plate somewhere? Can I leave the pump installed and block off the feeder hose?
What compression should this motor have? Do I check by removing both plugs and crank?
I have an oil leak coming from the bottom left of the motor. It appears to be coming from the control reed valve assy. Is this common, can I reseal with the motor installed?
