Results 1 to 2 of 2
    Jul 2006
    Ohio
    4
    Default Dies in the water --- 587 seadoo engine swap
    The engine blew in my 92 GTX, (white 587) and I replaced it with an earlier yellow 587.
    The motor runs like a top out of the water but on our "maiden voyage" she dies immediately when put in the water. Apparently I have some type of back pressure in the exhaust sytem. This yellow 587 motor has a different circulation pattern than the white engine and also has an additional coolant chamber in the crankcase/cylinder area. I did the best to consolidate the plumbing in the engine swap however, something must be screwed up.
    I bench tested the engine with a coolant "inlet" coming into the block and also to the forward top end of the exhaust header, (water injection inlet?). The exhaust/hull elbow is fed by the return at the cylinder head as well as the crankcase drain hose. The engine and exhaust ran nice and cool and air /water bleeders purged correctly from the top of the manifolds. I must be missing some type of vent that is causing exhaust back pressure?
    I appreciate anyones help and suggestions.
    21,545
    Default Re: Dies in the water --- 587 seadoo engine swap
    Thank you - SBT Mgt.
  1. Replies: 2
    Last Post: 06-04-2006, 01:47 PM
  2. engine sucking up water
    By postransformation in forum Polaris
    Last Post: 06-04-2006, 09:58 AM
  3. Seadoo 587 Engine
    By ViPER1313 in forum Sea-Doo
    Last Post: 07-29-2005, 01:44 AM
  4. White vs yellow engine 587
    By kestri in forum Sea-Doo
    Last Post: 06-23-2005, 08:56 AM
