I recently purchased a 1994 VXR and it has been running great up until last week. I will be riding around at WOT or half throttle and the ski will just die dead in the water. The strange thing is when I i hold the pin up where the key goes it starts right up and runs. Then I put the key back in and I get anywhere from 20 secs to a 15 min. run. I dont know if this is a common problem on these jetskis or not. It just seems when the pin that holds the key down is higher up it runs fine. I am a newbie and dont know much about them. Any help would be appreciated. Thanks alot.
1994 Yamaha VXR problem
This topic is closed.
Re: 1994 Yamaha VXR problem
Thank you - SBT Mgt.SBT Tech Support is here to help with your problems.
