I took my 2000, 750 sxi pro ski out for a test ride after installing the new SBT motor. The ski runs good at mid to full throttle. At low rpm's the ski will stall unless I continue to prime the carbs. (The ski ran great back at the house with a hose attached). Took the ski back home and pulled the carbs apart, to include the fuel pump. No dirt or residue noticed. Put the ski back together and tried again at lake. No change. Any suggestions?
Fuel problem?
Re: Fuel problem?
I suggest rebuilding the carb with a kit, taking them apart and looking does nothing. It's definitely a fuel issue.SBT Tech Support is here to help with your problems.
