If The Front Seal Is Bad Would It Cause A Piston To Burn A Hole In The Back Piston, Removed The Flywheel And The Seal Was In Pieces,i Was Wondering If I Could Put In New Seals, And Piston, Or Just Get Differant Motor. I Am Pretty New To This, But Im Starting To Like It!
I Recently Put A Top End Kit In It Because Of The Hole In The First Place But Did'nt Check For Pressure Until It Blew Another Holein The Same Rear Piston. Checked The Crank Seems To Be O K Bearings All Spin Good, Just Baffled Why A Front Seal Would Make The Rear Piston To Burn A Hole In It, Or Should I Be Looking For Another Reason
Any Reply Would Be Helpful
