Help with Break-in (pics of plugs)
  • Help with Break-in (pics of plugs)
    I am following the SBT break in procedure on my new motor and I have done the first two 30 minute cycles. Since I didn't know if the injection was working, I put pre-mix in as directed for a pre-mix engine. Well, the injection is working.
    Anyway, here are the plugs - do they look ok?
    edit: I cant see the images. try this
    http://www.pbase.com/st__stephen/image/66235280
    http://www.pbase.com/st__stephen/image/66235284
    Also, the pisser water is coming out very hot, looks like it is steaming, can only put my hand under it for a few seconds. Is this normal? It's not that hot on my sea-doo.
    Thanks for any help,
    Stephen
    Re: Help with Break-in (pics of plugs)
    The bypass water should be almost 200 degrees. As long as you don't see steam 9usually means a blown head gasket) it's fine. You can't read plugs during break-in. All those show is a lot of oil.
