Recently, I took the ski out and the engine was loading up badly coming out of the hole. The RPM's get to 4K and that seems to be the max it will do. I can feather the throttle and occasionally the RPM's will get back to the 6.5k to 7k range and runs great. When it is loading up, I can smell raw fuel. I checked the plugs, they are seated and torqued and they are not fouled. This began during the second tank of 10% methanol fuel. Any thoughts or troubleshooting paths I can follow?
2000 Ultra rpm's low then high
This topic is closed.
Re: 2000 Ultra rpm's low then high
Thank you - SBT Mgt.SBT Tech Support is here to help with your problems.
